Relay not clicking when opening on app
DFRobot XBoard Relay related questions and discussions.
Postby colby82 » Thu Oct 01, 2015 1:43 am
Hello,
I am brand new to this so please forgive my lack of knowledge. I am pretty certain that i've followed all of the steps but i cant seem to get the relays to fire using the iphone app. I've loaded the .ino from the link in the instructions and did as the instructions said and entered the ip address and also a password. I am able to see the following on my local network and also outside of my network since i've forwarded the port that i desingated:
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<myDoorOpener>
<status statusPin="3">Closed</status>
<status statusPin="4">Closed</status>
<challengeToken>Cyber661663</challengeToken>
</myDoorOpener>
I have setup the iphone app and it appears to be working when you press the button to open the garage, but nothing happens on the garage door and the relay doesnt make a sound either.
Here is a copy of the .ino file, maybe someone can see if they notice something wrong with it?
// Copyright (C) 2009 - 2012, MyDoorOpener.com
// Release Notes:
// v1.0 [02/23/2010] - Initial release
// v1.1 [03/02/2010] - Added support for up to three garage doors.
// v1.2 [08/11/2010] - Deprecated HTTP POST in favor of HTTP GET parameters.
// - Added additional serial debugging.
// v2.0 [05/11/2012] - Updated to support unlimited number of devices (used to be max 3).
// - Updated to support Arduino v1.0 IDE.
// v2.2 [12/15/2012] - Updated to support SMTP email notifications
// - Updated to support SMS notifications (via carrier provided SMTPtoSMS gateway)
// - Updated to support iOS push notifications (via Prowl)
// - Added logic to support multiple status reading strategies (3v5v, NC, NO, etc)
// - Relocated most string literals to flash memory
// - Certified compatibility with ArduinoEthernet (all-in-one) and DFRobot RelayShield hardware
// - Certified compatibility with Arduino v1.0.3 IDE
// v2.3 [11/16/2014] - Certified compatibility with DFRobot Xboard Relay (which is now the new standard/default)
// - Certified compatibility with Arduino v1.0.6 IDE
// v2.4 [12/14/2014] - Reduced memory footprint by getting rid of "WebDuino" library
//#define MYDOOROPENER_SERIAL_DEBUGGING 1
//#define NOTIFICATIONS_SERIAL_DEBUGGING 1
//#define SMTP_SERIAL_DEBUGGING 1
//#define PUSH_SERIAL_DEBUGGING 1
#include "MyDoorOpenerServer.h"
uint8_t ip[4] = { 192,168,1,20 };
// Port on which Arduino HTTP server will listen to
int port = 8888;
// MAC address to be used by ethernet adapter
uint8_t mac[6] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// password required for operating door [max length = 16] (status fetching doesn't require password). This
char* password = "TempPW";
// Do not remove the following server definitions
EthernetServer server(port);
MyDoorOpenerServer myDoorOpenerServer(password, mac, ip);
// Device/Door configuration (relais and sensors)
//uint8_t relayPins[] = { 9 }; // single device at pin #9
//uint8_t relayPins[] = { 2, 3, 4, 5 }; // select if using DFRobot RelayShield
//uint8_t relayPins[] = { 2, 3 }; // two devices at pins #2 and #3
//uint8_t relayPins[] = { 2, 3, 4, ... }; // even more devices at pins #2, #3, #4, etc ...
uint8_t relayPins[] = { 7, 8 }; // select if using DFRobot XBoard Relay
//uint8_t statusPins[] = { 3 }; // single device at pin #3
//uint8_t statusPins[] = { 2, 3, 4, 5 }; // select if using DFRobot RelayShield
//uint8_t statusPins[] = { 2, 3 }; // two devices at pins #2 and #3
//uint8_t statusPins[] = { 2, 3, 4, ... }; // even more devices at pins #2, #3, #4, etc ...
uint8_t statusPins[] = { 3, 4 }; // select if using DFRobot XBoard Relay
// Comment if not using XBoard Relay
#define USING_XBOARD_RELAY
//#define STATUS_STRATEGY_3VCLOSED_5VOPENED // initial approach - uses analogRead combined with STATUS_OPEN_TRESHOLD (opened == +5v, closed == +3v)
#define STATUS_STRATEGY_NORMALLY_CLOSED // classic door sensor - uses digitalRead to interpret door/device status (opened == high-impedance, closed == GND)
//#define STATUS_STRATEGY_NORMALLY_OPENED // alternate approach - uses digitalRead to interpret door/device status (opened == GND, closed == high-impedance)
//#define NOTIFICATIONS_WATCHDOG_MINUTES 5
//#define NOTIFICATIONS_OPEN
//#define PUSH_NOTIFICATIONS
char prowlApiKey[] = "paste-your-prowl-provided-api-key-here";
char prowlServerName[] = "api.prowlapp.com";
int prowlServerPort = 80;
char prowlApiBaseUrl[] = "/publicapi/add";
// if defined, will fire notifications using SMS notifications (uncomment to turn ON - rember to adjust SMTP settings too)
//#define SMS_NOTIFICATIONS
char smtpToForSms[] = "your-mobile-number@your-carrier-gateway.com";
//#define SMTP_NOTIFICATIONS
char smtpServerName[] = "smtp-server.your-isp.com";
// set to your ISP's SMTP server port (typically port 25)
int smtpServerPort = 25;
char smtpToForEmail[] = "your.address@gmail.com";
// Misc configuration constants (should not require any changes)
// number of milliseconds relay pin will be held high when triggered.
int RELAY_DELAY = 1000;
// misc size constants
#define HTTP_PARAM_NAME_SIZE 16
#define HTTP_PARAM_VALUE_SIZE 64
#define PASSWORD_HEX_SIZE 32
#define PASSWORD_SIZE 16
#define AES256_CRYPTO_KEY_SIZE 32
#define CHALLENGE_TOKEN_SIZE 16
void getUrlEncoded(const char* msg, char* encodedMsg)
const char hex[] = "0123456789abcdef";
while(*msg != '\0')
if(('a' <= *msg && *msg <= 'z') || ('A' <= *msg && *msg <= 'Z') || ('0' <= *msg && *msg <= '9'))
*encodedMsg = *msg;
encodedMsg++;
*encodedMsg = '%';
encodedMsg++;
*encodedMsg = hex[*msg >> 4];
encodedMsg++;
*encodedMsg = hex[*msg & 15];
encodedMsg++;
msg++;
EthernetClient pushClient;
void notifyViaPush(const char* subject, const char* body)
Serial.print(F("*** Push - server name: '"));
Serial.print(prowlServerName);
Serial.print(F("' - "));
Serial.print(F("apiKey: '"));
Serial.print(prowlApiKey);
Serial.print(F("subject: '"));
Serial.print(subject);
Serial.print(F("body: '"));
Serial.print(body);
pushClient.print(F("&url=mydooropener%3A%2F%2Fstatus"));
Serial.println(F("*** Push - completed ***"));
EthernetClient smtpClient;
void notifyViaEmail(const String& to, const String& subject, const String& body)
#if defined(SMTP_SERIAL_DEBUGGING)
Serial.print(F("*** SMTP - server name: '"));
Serial.print(smtpServerName);
Serial.print(F("to: '"));
Serial.print(to);
Serial.print(body);
if (smtpClient.connect(smtpServerName, smtpServerPort))
Serial.println(F("*** SMTP - connection established ***"));
smtpClient.println(F("HELO relai.mydooropener.com"));
smtpClient.print(F("MAIL FROM:"));
smtpClient.println(F("noreply@mydooropener.com"));
smtpClient.print(F("RCPT TO:"));
smtpClient.println(to);
smtpClient.println(F("DATA"));
smtpClient.print(F("SUBJECT: "));
smtpClient.println(subject);
smtpClient.println();
smtpClient.print(body);
smtpClient.print(F(" "));
smtpClient.println(F("mydooropener://status"));
smtpClient.println(F("."));
smtpClient.println(F("QUIT"));
smtpClient.stop();
Serial.println(F("*** SMTP - connection stopped ***"));
Serial.println(F("*** SMTP - completed ***"));
void notifyViaEmail(const char* subject, const char* body)
notifyViaEmail(smtpToForEmail, subject, body);
void notifyViaSms(const char* subject, const char* body)
notifyViaEmail(smtpToForSms, subject, body);
#if defined(USING_XBOARD_RELAY)
pinMode(pinNumber+18, INPUT_PULLUP); // addressing analog pins as digital pins (+18)
#else
pinMode(pinNumber+14, INPUT_PULLUP); // addressing analog pins as digital pins (+14)
int status = digitalRead(pinNumber+18); // addressing analog pins as digital pins (+18)
#else
Serial.print(F("*** isOpen - status value for pin: '"));
Serial.print(pinNumber);
Serial.print(F("' is '"));
Serial.print(status);
boolean retVal = false;
retVal = status >= STATUS_OPEN_TRESHOLD;
#elif defined(STATUS_STRATEGY_5VCLOSED_3VOPENED)
retVal = status <= STATUS_OPEN_TRESHOLD;
retVal = status == LOW;
#elif defined(STATUS_STRATEGY_NORMALLY_OPENED)
retVal = status == HIGH;
Serial.print(F("' returing: '"));
void watchDogNotificationsHandler()
char subject[] = "MyDoorOpener Notification";
sprintf(body, "A door or device has been opened for more than %i minute(s).", NOTIFICATIONS_WATCHDOG_MINUTES);
// can be sent. This is done to avoid floading recipient with notifications for a same event occurrence.
void openNotificationsHandler()
Serial.print(F("*** open notification handler - detected an opened device/door @ pin #"));
Serial.println(F("*** open notification handler - sending notification ***"));
char body[] = "A door or device has just been opened.";
Serial.println(F("*** open notification handler - NOT sending notification ***"));
// if all door/devices are closed, reset notificationSent semaphore so that further notifications
#if defined(MYDOOROPENER_SERIAL_DEBUGGING) || defined(WEBDUINO_SERIAL_DEBUGGING) || defined(SMTP_SERIAL_DEBUGGING) || #defined(PUSH_SERIAL_DEBUGGING) || defined(NOTIFICATIONS_SERIAL_DEBUGGING)
Serial.begin(9600);
Serial.println(F("*** MyDoorOpener setup begin ***"));
configureStatusPin(statusPins[i]);
for (int i = 0; i < sizeof(relayPins); ++i)
pinMode(relayPins[i], OUTPUT);
digitalWrite(relayPins[i], LOW);
myDoorOpenerServer.setup(statusPins, sizeof(statusPins));
Serial.println(F("*** MyDoorOpener setup completed ***"));
myDoorOpenerServer.loop();
colby82
Re: Relay not clicking when opening on app
Postby support » Sat Oct 03, 2015 9:21 am
The first thing that comes to mind is: have you configured the relay pins on the iPhone app for that device/door to match the one in your .INO file?
Postby colby82 » Sat Oct 03, 2015 9:54 am
Thanks for the response! Yes I have selected the correct pins in the iOS appbased on what I have setup in the .ino file .
When I press the open button on the app I can see the led's light up, but I just can hear the relay make a noise. I would like to confirm I didn't damage the board, is there a way to get a copy of the sketch that comes preloaded on the xboard that makes the relays fire repeatedly to show they are working? That what I can tell of its the board of the sketch, I think?
Colby
colby82
Postby support » Sat Oct 03, 2015 10:17 am
Postby colby82 » Sat Oct 03, 2015 10:54 am
I just tried loading some sample code and I can get the relay to fire using it, so im really not sure what the issue is. Here is a screen shot of the iOs app to show the correct relay pins are selected.
iOs app screen shot
colby82
Postby colby82 » Sat Oct 03, 2015 11:23 am
I was abel to get the relay pin to fire using the iOs app by removing one of the pins that were defined
here is the old line of code:
here is the new:
uint8_t relayPins[] = { 7 }; // select if using DFRobot XBoard Relay
i'm getting a time out error on the iOs app that i wasnt getting before but now i can get the relay to fire!
Babysteps i guess :)
colby82
Postby support » Tue Oct 27, 2015 8:06 pm
Glad things are working out for you. Thanks for sharing what your solution was ...
Return to DFRobot XBoard Relay
