Prowl notifications not sending
Postby johnt365 » Sat Sep 19, 2015 7:17 pm
I've had a great time setting up this project and Prowl notifications are all that remain.
* I am able to access the Xboard from the iPhone app and control the door.
* I also have a sensor that reports open and closed correctly in the app. (I did have to change it to NORMALLY_OPENED to report)
* I am able to receive a Prowl notification using the Prowl API email address.
* I am using port 80
I am not sure what I am missing or could it be that my ISP does not allow this or requires some other setting? I use Time Warner Cable for an ISP. Curious if anybody has any tips or experience with this matter.
Thank you for any help you can offer.
Cheers!
John
Here is how I have things set up.
#define STATUS_STRATEGY_NORMALLY_OPENED // alternate approach - uses digitalRead to interpret door/device status (opened == GND, closed == high-impedance)
// #define NOTIFICATIONS_WATCHDOG_MINUTES 5
#define PUSH_NOTIFICATIONS
# if defined(PUSH_NOTIFICATIONS)
char prowlApiKey[] = "025c3bxxxxxxxxxxxxxxxxxxb2b8XXXX";
char prowlServerName[] = "api.prowlapp.com";
int prowlServerPort = 80;
char prowlApiBaseUrl[] = "/publicapi/add";
johnt365
Re: Prowl notifications not sending
Postby support » Sun Sep 20, 2015 9:15 am
Hey,
Glad to hear you're having fun playing around with this ...
Have you searched this forum for similar issues. There are few other threads on this particular topic and for some users,
they needed to change the MyDoorOpenerServer constructor, to use that one where you can specify DNS and Gateway.
Try looking into that and see if that works for you as well. Best regards,
Postby johnt365 » Mon Sep 21, 2015 6:07 pm
Hello Support,
I found this on the second tab. This is now it is configured now. Does this look correct or does it need to be changed?
I am not really familiar with this programming and would appreciate any guidance if edits are needed to the code below.
if (dns != NULL)
if (gateway != NULL)
Ethernet.begin(mac, ip, dns, gateway);
Ethernet.begin(mac, ip, dns);
Ethernet.begin(mac, ip);
server.begin();
johnt365
Postby support » Mon Sep 21, 2015 7:58 pm
No, you don't need to change that code per say, but instead change the constructor used (which will indeed have that code your found, executed).
Look at this specific post/reply:
viewtopic.php?f=2&t=316#p785
Postby johnt365 » Wed Sep 23, 2015 7:52 pm
Thanks again for the help. I am afraid my lack of programming knowledge is showing. Would you be able to point specifically to the area that needs to be changed and let me know what to change it to? I am not sure if I am even close. I am really driving blind at this point and could use all the help you can offer.
Thank you again for helping me get this far.
John
johnt365
Postby TVTuga » Wed Sep 23, 2015 8:34 pm
John,
did you enter the Router IP Address as the Gateway , attached is the screen shot of my set up
TVTuga
Postby johnt365 » Wed Sep 23, 2015 10:03 pm
Thank you very much for the clarification. I have a minor networking question now. Here is how my network settings look now.
My local IP is the same as you set for your gateway. However, my gateway and Local DNS are just 0.0.0.0
How do you know what to put there or can I leave it as 0.0.0.0?
I tried to set the gateway and local Ip as the same number but that did not send the notifications.
Thank you again on this the screen shot was a big help
John
johnt365
Postby TVTuga » Thu Sep 24, 2015 8:50 pm
Hi John
The Gateway is the Router IP Address , and the IP Address is the IP that you want to give it to the MyDoorOpener
Regards
Victor
TVTuga
Postby johnt365 » Tue Oct 06, 2015 9:52 pm
Thank you again for all of the help.
Victor I really appreciate you sharing your experience with me. I would not have figured this one out by myself.
John
johnt365
