Controlling other devices
Postby nicholasvanh » Fri Apr 25, 2014 1:06 pm
In the description it describes that this app can control lights gates and fire places. But for instance my fireplace needs a sustained contact closure for it to on. How do you go about setting it up to accomplish this. There is also a picture of a table lamp, obviously you wouldn't want it to just blink on a for second.....I must be missing something?
nicholasvanh
Re: Controlling other devices
Postby support » Sat Apr 26, 2014 7:28 pm
The app triggers a relay. What the trigger does after, is up to you ... You could for
instance have something toggle the lamp/fireplace ON or OFF upon being triggered.
There has been a feature request to add latching output support to the app. See
following thread:
viewtopic.php?f=13&t=222
That feature will most likely be included in our next release. Add your vote on
that thread to make it count even more.
Postby ski73 » Tue Aug 05, 2014 8:34 am
I'm trying to control a garage light to latch on, I found some code for this on this board but I keep getting a compile error? Can anyone help?
Arduino error2.PNG (23.49 KiB) Viewed 7539 times
ski73
Postby support » Thu Aug 07, 2014 7:59 pm
You seem to be having extraneous closing braces } following the end of your ELSE block ...
Each opening brace '{' should have a matching closing brace '}' ...
